when I try to change a float data type from user input I get this error # ValueError: invalid literal for int() with base 10:
Abdulla-Qaladzay
Abdulla-Qaladzay
this is how I solve it
if I excite this line :
val = int(input("wsp?!"))
 and in-put a float value  I get the error that I mentioned in the title of the post
so
this is how I got rid of it by the help of eval()  command:
val = int(eval(input("wsp?!")))
This error is not only happen in Maya
I tried it with almost all newer versions of python than 3.7.7 in all the versions I got the error and the solution worked in all of them
With python 2 that was OK I didn't get the error
I am not sure that could be something that I misunderstood cause I don't have much experience with python
so I am sorry if that it the case
e_honda
Hi.
If I do not misunderstood the problem, I believe that the data type from user input is a string, not a float.
As so, you cannot convert a "float string" to "int" directly.
You should do a string -> float -> int conversion like below.
val = int(float(input("wsp?!")))
The eval command will act like the float conversion, but could be a security vulnerability because it will evaluate any code string.
Probably more explanations could be found in stackoverflow threads like those below.
https://stackoverflow.com/a/27048725
https://stackoverflow.com/a/26330367
Hope it helps.
