Hello!
It's my first time creating and applying normal maps. It seems to me that normal map is okay, but I have a problem with applying it on mesh. It seems to duplicate normal map many times and apply it on mesh, making it small in size. Maybe the problem is in 'Repeat UV' field, but even if I change the values from '1.000' to '0000' it doesn't help. What should I do?
Thank You in advance!
Yes, I've modeled this and created UV map. Can you please point out what is wrong in particular with the UV mapping?
From what it looks like on your model....it doesn't look like you're using your UV map but maybe another one.
Right click on your model and go down to UV sets and make sure you are using the correct map.
