Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Grid no longer displays in top view.
9 REPLIES 9
Message 1 of 10
2166 Views, 9 Replies
I can toggle the view on and off in the other 3 view ports, and it looks like it changed because the background changes, but the grid is not redrawn. Obscure setting or bug?
9 REPLIES 9
Message 2 of 10
mspeer
Hi!
Check Camera Attributes, Near Clip Plane and Far Clip Plan, or simply post the scene-file.
Message 3 of 10
in reply to: mspeer
Check them for what?
Message 4 of 10
mspeer
Hi!
Please upload the scene-file, ( i don't need any objects if only the grid is affected)
Message 5 of 10
in reply to: mspeer
May have just figured this out, but since I didn't change it in the first place I don't know where to go to fix.
Is it possible that the grid is so dense that it appears as a solid surface? Where do you go in this "UI" to check? Of course this assume you can change the grid size in a view-by-view basis. In all the other views grid displays as expected.
Message 6 of 10
mspeer
Hi!
The grid is the same for all views, but of course you can move your camera and the grid density changes with camera distance, it can also disappear if the camera is very far away (dependent on your grid settings).
Message 7 of 10
in reply to: mspeer
Then Maya is broke because the zoom level is about the same for all views...
Message 8 of 10
mspeer
Hi!
What happens if you Zoom in and set the Viewport Renderer back to Viewport 2.0?
Message 9 of 10
cornelh
@Anonymous
This could be due to your camera clipping plane.  If that doesn't fix it, then try to reset your prefs. without access to your file, it is hard to tell what is going on.  not all the views have the same clipping plane defaults so please check that.  Make sure you have have the grid turned on as well (I assume you do, but worth the ask).
Then as others have mentioned, you might be past the Grid and zooming out might reveal it.  Good luck!
Message 10 of 10
SophieStudent
in reply to: cornelh
Hi.  My grid didn't show in front view and I simply pressed the A-KEY and F-KEY on KEYBOARD a few times and after a few secs the grid came back into view!
