Wedge an Edge
Wedge an Edge
Message 1 of 9
Wedge an Edge
Hello! Do you think its possible to use Wedge Tool on edge? I wish to curve my plane.
Bridge in smooth path+curve almost does the trick. but messes with vertices a bit (see the pic)
Replies (8)
Message 2 of 9
hamsterHamster
You can either increase the number of divisions, or correct the overlaps manually (be a sculptor, an artist, do eyeballing).
If this doesn't suit your workstyle/needs, then possibly you might reconsider a different set of actions, to model same thing with less manual input.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 3 of 9
thank you for suggestions!
Message 4 of 9
mihirsbcc
Message 5 of 9
thank you! tho in this video they using Wedge on faces.
And generally speaking, Maya doesn't have Wedge option when you select edge but not face.
I was just hoping to get some wise hacks here 🙂
Message 6 of 9
_sebastian_f
model corner > bevel edge
edit: depending on your exact goal and project requirements your result could be considered correct and probably just shows your corner radius is too small.
Message 7 of 9
yes, thank you! the only thing is that I'm looking for this, not that
Message 8 of 9
_sebastian_f
somehow expected that;)
as before model the corner, bevel it, duplicate and offset/transform component, move down-combine-bridge, delete unused faces, bevel inner edge.
or:
create corner, bevel, extrude with thickness, remove unused faces, bevel inner edge.
last but not least:
step 1& 2 as before, extrude bottom edge, bevel inner edge.
Message 9 of 9
oh, this is very nice! although I wished to make those changes with already made angles of already made mesh.
but thank you nonetheless!
