Hello, I'm new to maya. I modeled building in Revit and for rendering and texturing I exported as FBX to use in may, everything worked perfectly until here, I wanted to assign texture to lamps but revit exported as single mesh, then I went mesh>separate command, it separated perfectly but every same lamp disappeared except my selection and at the outliner window all the lamp objects become transform node including the selection.
Thank You.
