view port background problem unable to change the gradient
selvakvigneshmaya
Message 1 of 10
selvakvigneshmaya
there is some issue in changing the gradient color i tried reseting and before i also tried windows - settings - color settings too
Replies (9)
Message 2 of 10
stephenkmann
Can't tell from your video if you are every actually displaying gradient as your background.
Toggle thru all the views using alt + b   until you get to the gradient bg.   And then use the color manager to change the top and bottom..
If you aren't in the gradient BG,  the  changes won't be visible
hth
-=s
Message 3 of 10
selvakvigneshmaya
Yes sir i tried those things but in the four colors svsilsble for changing the backround gradient color is not showing instead  it shows a normal color .I tried resetting maya  even then it shows the samecolors not able to chnage to gradient
Message 4 of 10
selvakvigneshmaya
Finally found the error its because of the newly installed AMD driver .
Message 5 of 10
daveSchoneveld
Did you fix this issue? I also have this issue. I don't see how the latest driver causing it is the solution. Did you roll back your driver? I'm having trouble doing that.
Message 6 of 10
selvakvigneshmaya
Yes, it was my latest update Amd  driver that caused the problem try to uninstall it.
Message 7 of 10
daveSchoneveld
Well this is a new card and this is the driver it came with so its kind of a pain to try to install an older driver thats not rolling back. I'm just going to suffer with it until one day, magically the problem goes away. Sort of like the disappearing and/or unselectable geo in viewport thats been going on for years and multiple versions of maya (on both cards, on many computers) Its annoying but if you find it in the outliner and select it there, you fix it!
Message 8 of 10
selvakvigneshmaya
Good luck
Message 9 of 10
daniel_fandino10HJU43
Community Visitor
Community Visitor
I have the same problem, wich version of drivers works?
Message 10 of 10
daveSchoneveld
I just bought an Nvidia card, and sold my Radeon one. I know that's not ideal but it was simple.
