Uv problem
Uv problem
Message 1 of 8
Uv problem
Hello. As you can see after unwrapping some parts of my model don't display those squares on the surface, that indicate UV map. They are completely grey. I cant apply textures on this part correctly. Because UV is simply not there. What might cause such a problem? scr3.jpgscr4.jpg
Replies (7)
Message 2 of 8
_sebastian_f
check for multiple uv sets and delete what´s not needed.
Message 3 of 8
I have only one UV set. No multiply Uvs.
What Else could be the problem?
The model is unwrapped but some parts have no uvs map on it.
Message 4 of 8
mspeer
Hi!
Maybe there are no UVs for these faces.
Please upload a scene-file, that's far easier for troubleshooting.
Message 5 of 8
Yes. Please check it. I uploaded it here https://dropmefiles.com/YLQBs
Message 6 of 8
mspeer
Hi!
My assumption was correct.
You have faces on top of each other and those duplicate faces don't have UVs assigned.
Message 7 of 8
Thank you very much! You saved my day. But how did u manage to move double faces aside?
Message 8 of 8
mspeer
Hi!
I just selected all faces (of this shell) with double click on one faces with face component mode active and then moved them.
