Smooth Mesh Problem. Plz help
Message 1 of 9
Hello Guys,
I have Maya 2020, while I am completing my face modeling project, one weird problem is bugging me.
Everything seems fine in normal mode(5) until I press 3key(smooth). The polygon mesh changes, it goes inwards leaving a big carved bump, I have tried deleting history/ assigning new material, and I even tried changing the problematic mesh faces with the duplicated mesh, nothing works.
Someone, please help me, I appreciate it a lot.Screenshot (55).pngScreenshot (54).pngScreenshot (52).pngScreenshot (53).png
Replies (8)
Message 2 of 9
mcw0
In normal mode, when you select one of the edges that is causing this problem, do you get just one edge or more than one?
Message 3 of 9
just one edge bro.
I checked the vertices.
Message 4 of 9
mspeer
Hi!
Please provide a scene-file.
Message 5 of 9
how can I send you a Maya binary file here?
Message 6 of 9
mspeer
Hi!
You can  attach files below the text field of the reply.
Just look for "Drag and drop here or browse files to attach".
Please ZIP the data first.
Message 7 of 9
here u go, brother.
Message 8 of 9
mspeer
Hi!
The normals are reversed.
At first in Viewport use
Lighting -> Two Sided Lighting (uncheck),
then you can see the problem.
Use
Mesh Display -> Conform
Mesh Display -> Reverse
to correct this.
Message 9 of 9
Thank you so much 🙂
