Slice faces where they are intersected by a polygon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I've just started to learn Maya and I think I did something wrong with this model:
The small cylinder is inside the biggest one.
I know how to remove the part of the small cylinder that it is inside the biggest one, but I don't know how to remove the parts of the faces that are hidden by the small cylinder.
I have tried to use the multi-cut tool to slice the faces but it seems that I don't know how to use it. And also, the edge loop tool with the same result.
How can I remove the parts of the faces that are hidden by the small cylinder?
By the way, I have attached the model's file if you want to check what I did.
Thanks!
