i am trying to learn uv so consider an object and the same object duplicated with smooth from mesh menu is applied there i see a good differeence in the stretchness (colored red ) and compression (colored blue ) .
MY QUESTION
1.IS APPLYING SMOOTH IS THE ONLY WAY TO AVOID ANY RED AND BLUE COLOR
2.WHAT IF THE COMPANY I M GOING TO WORK ASKS REDUCE THE NUMBER LIKE A LOW POLY
AND
3.WHETHER IS IT OKAY TO HAVE LITTLE RED AND BLUE OR SHOULD COMPLETELY AVOID
attached the files too pls check
WITHOUT SMOOTH
WITH SMOOTH
