applying smooth for uvs
selvakvigneshmaya
selvakvigneshmaya
i am trying  to learn uv so consider an object and the same object duplicated with smooth from mesh menu is applied there i see a good differeence in the stretchness (colored red ) and compression (colored blue ) .
MY QUESTION
1.IS APPLYING SMOOTH IS THE ONLY WAY TO AVOID ANY RED AND BLUE COLOR
2.WHAT IF THE  COMPANY  I M GOING TO WORK ASKS REDUCE THE NUMBER LIKE A LOW POLY
AND
3.WHETHER IS IT OKAY TO HAVE LITTLE RED AND BLUE OR SHOULD COMPLETELY AVOID
attached the files too pls check
WITHOUT SMOOTHWITHOUT SMOOTHWITH SMOOTHWITH SMOOTH
Christoph_Schaedl
Its near impossible to avoid red and blue. Your work is fine. What is more important is that you have straight uv borders.
https://linktr.ee/cg_oglu
selvakvigneshmaya
thanks
