Problem with transfer Attributes
tori.defelice.221
tori.defelice.221
Hi, I am having a bit of trouble with the transfer attributes. I modeled a character completely in Maya then I exported the model to ZBrush where I placed textures and color and afterwards I exported the model back into Maya with the UV map. Once the model was imported back into Maya alongside the UV maps, I followed along on a tutorial, I made a duplicate of the model then I opened the options window of transfer attributes where I selected topology. The problem started when I hit the apply button on the transfer attributes where nothing happens however a new tab opens up in the attributes editor.  I even made sure that the model doesn't have non-manifold geometry and if was clean. Can someone help?
The image below is showing what happens when I press the apply button on the menu of the transfer attributes and it opens up a tab in the attributes editor tab.
New Edit: I installed the new Maya both 2023 and 2024 versions to see if updating would work but unfortunately it didn't work and still does the same thing as above. Need some help please.
tori.defelice.221
tori.defelice.221
Can someone please help me and solved this problem. Nothing is working. Why is not working for me but it works for anyone else.
tori.defelice.221
Update: The transfer attributes does work on everything else but a Zbrush head to Maya head UV map. Can someone please help me and solved this problem. Nothing is working. Why is not working for me but it works for anyone else.
