Move two objects in opposite directions
Hello.
I have a model with two arms: one on the left and one on the right.
They are two separate objects. I want them to get closer to the body, so I want them to move to a common center point.
Here is an example:
I want both arms to move toward the point at the center (which is the midpoint of the distance between the two objects)
pshwayka
I would delete one of the arms and use Edit->Duplicate special with a scale of -1. Make sure you snap your pivot to the centerline first.
Mel script based on simple grouping and special duplicate options
performGroup false;
performDuplicateSpecial false;
doGroup 0 1 1;
instance; scale -r -1 1 1;
After making instance select it and move
