Mirror surface problem
I'm trying to mirror a surface but I get some problems with it as you can see in the pic.
I've remade the surface twice from scratch but with the same result.
Skärmavbild 2014-09-30 kl. 11.23.53.pngSkärmavbild 2014-09-30 kl. 11.24.08.png
tdHendrix
Hi, after you do the mirror geometry look over in the channel box and you should see a node called polyMirror under the Inputs section. Try to lower the attribute named Merge Threshold until the vertices aren't snapping together anymore.
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
Sweet.. thx alot.
I would never have found it 🙂
