Create instance after duplicating?
If you Duplicate Special, you can create an instance where you manipulate one object and all it's duplicates get the same manipulation. What if I regular duplicated, and a while later decide that I wanted to instance it. Is it possible or is it too late? They are identical objects...
You can try "Modify> Replace Objects" to replace the copies with instances. Hope this helps!
Wow thats awesome, thanks so much!!!
