Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Invert Selection -> Delete Faces: Remaining faces collapse
4 REPLIES 4
1452 Views, 4 Replies
So this keeps happening and it's driving me nuts. If I extrude faces and then invert selection and delete, my remaining faces collapse in unpredictable ways. Sometimes a jumble of verts like a crumpled piece of paper, sometimes they disappear completely, sometimes like in the following pictures. If I deselect and then go through and manually select faces to delete, and then delete, there is no problem... :dunno:
4 REPLIES 4
jordan.giboney
Hi @Anonymous
Thanks for posting! I've been trying to replicate this on my machine but haven't been having any luck - very strange! is this behavior tied to the specific scene you are working in? Aka, if you go to a new empty scene and follow the same steps with a poly primitive (cube, sphere, etc.), does the same behavior happen?
Also, I have you tried shutting down Maya and Resetting your preferences to default?
Thanks for being a part of our community! I look forward to hearing from you.
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Hi @Anonymous
I hope you are doing well 🙂 I wanted to check in and see how things were going. Did you have a chance to try my suggestions? Any new developments with this behavior?
Let me know if there is anything I can help with! 🙂
Jordan Giboney
in reply to: jordan.giboney
Hi there.
No it happens on many scenes. at first I thought it was because a duplicated object was sharing a transform node or some sort of heirarchial problem. It does it more often than not and I have tried resetting preferences to no avail.
I also have a problem that may be related in that duplicated objects want to follow other objects into and out of layers, and will not delete from layers.
Makes it seem like it's a glitch. I'm going to update to 2019 and see what happens. I'll check back in. Thanks for your responses.
I'll attach a scene file next time it happens.
Best,
Jim
This is happening to me in 2019 as well.      The only fix I could find was to remove History on the object before deleting the faces.   another annoying step ha.
Technology Administrators
