Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
xgen grass not applying to entire surface
4 REPLIES 4
yyumii
664 Views, 4 Replies
Im trying to get grass over my topo surface but the grass only appears on a portion of the surface. any ideas why?
Thank you
4 REPLIES 4
sean.heasley
in reply to: yyumii
Hi @yyumii
Do you have any masks applied?
Also, can you try unloading your Xgen plugins then re enabled them to see if anything changes?
sean.heasley
in reply to: sean.heasley
Hi @yyumii
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
yyumii
in reply to: yyumii
There was no mask applied. i went back to the file a few days later and it seemed to work fine that time. its hit or miss. I believe that it is just the size of the model combined with the fact that it is a mesh from revit.
sean.heasley
in reply to: yyumii
Hi @yyumii
Hmm ok.
I'll mark this as solved for now but please let me know if the issue comes back or if anything changes!
