Windows/shelves have gone awol!
Hiya, I have been click-happy with my windows and even after using Maya for 3months this is the first time I have managed to completely mess up my shelves and windows.
I have tried changing my preferences and creating a new scene to help it go back to normal.
On the Help they recommend that too.
I've also tried to reverse engineer where I've stripped a shelf from its "home" by holding the LMB and trying to insert it back into the shelf.
This doesn't work either.
I've attached a screenshot of my current Maya and a screenshot of my usual/normal Maya setup.
Any ideas? And apologies in advance if it is very obvious and simple, I probably can't see the wood for the trees.
Sinead
Hi . In Documents\maya\2018\ delete the pref folder or rename it prefold . open maya , it will ask you to either create new default preferences or copy old , select on create new
Hiya, thanks for the advice.
There is no "2018" folder in Documents/Maya. It only shows Projects.
In the specific project folder could I change something in "Autosave"? or the list shown in the screenshot.
I'm using a Mac - not sure if this makes a difference.
Sinead
What does exist is the following attached in Applications...
Hiya,
I eventually found the location of Maya/2018...gotta love Macs- life would be too simple otherwise!
Thank you 🙂
Sinead
