Maya 2017.4 Linux plugins not appearing
3bdullah.battat
Observer Observer
3bdullah.battat
Observer
Observer
Hello everyone,
I'm running Maya 2017 update 4 on Linux CentOS 7.
The problem is, everytime I run Maya I have to load arnold and redshift, even if they are auto-loaded !! And sometimes when I render using them, they get unloaded.
Maya is not crashing, they just disappear.
I hope there's a solution, thanks in advance.
sean.heasley
Hi @3bdullah.battat and welcome to the community!
We officially support version 7.2 for Linux so you may need to update your OS in order for this issue to go away.
Another option you may want to try is uninstalling Arnold completely, deleting your settings/preferences, then reinstall Arnold and see if the issue still occurs.
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @3bdullah.battat
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
