Why can't I use multi cut tool?
Hello dear community
From this morning I can not use the MultiCut tool properly anymore, Like I used to click on wherever I wanted and make a vertex and then move and shape my mesh, Basically makes me unable to do anything, Unfortunately I can not take a screenshot because the Icon of multicut toll will disappear, So I recorded a video, It shows like the Cut tool + a STOP SIGN!
https://upload.cat/4ad8279e1514caf7
I add the music at the end for fun 😄
What should I do?
-Thanks
sean.heasley
Hi @Anonymous
You have symmetry enabled which is why the tool isn't working! If you go to the top and disable symmetry you should be able to use the tool normally.
Also 10/10 edit adding the rick and morty piano at the end lol.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
