How to prevent seeing through the meshes?
Hello dear community
I imported this Targa files and then assign it to my plane ...
I duplicated each mesh and Reverse and combine it together, to make the mesh from behind visible too ...
So the problem is, When I rotate the camera and moving around, Some how the meshes get invisible, Transparent and I can see through, What is the problem?
Here is everything good both from top and behind view:
But in side view it shows like this: (shadowy,Black, Seeing through....)
What should I do?
-Thanks
damaggio
You can change your viewport transparency settings in Viewport 2.0 , also keep in mind to rely on the rendered image and not just the viewport.
