Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
UV snapshots blank/black
16 REPLIES 16
Message 1 of 17
15985 Views, 16 Replies
When I try to take UV snapshots they turn out black if I do anything more than one cube or shell. Is this an issue with the recent updates or am I making a noob mistake? TIA
16 REPLIES 16
Message 2 of 17
mspeer
Hi!
No problem here with Maya 2017 update 4.
Message 3 of 17
sean.heasley
Hi @Anonymous and welcome to the community!
    Make sure you have your object selected when you hit UV snapshot and also make sure it is in a tga or png format. If that doesn't work feel free to attach your scene here and I will take a look at it!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 4 of 17
sean.heasley
in reply to: sean.heasley
Hi @Anonymous just checking in, are you still having this issue?
Message 5 of 17
Freedan
Did you find a solution? I'm having the same problem after downloading Maya 2018. Tried resetting the settings and everything, but nothing. Every time I try to take a UV Snapshot, the image is blank/black.
Message 6 of 17
sean.heasley
in reply to: Freedan
Hi @Freedan
Did you try the steps I provided above?
Message 7 of 17
Freedan
Yes, I have tried all that. Still getting nothing but a blank, black image. Never had this problem before until I upgraded to 2018.
Message 8 of 17
sean.heasley
Hi @Freedan
Can you attach the scene file here or via dropbox/google drive so I can take a look at it?
Message 9 of 17
john.paul.giancarlo
I can not reproduce this, please add an image showing how you are doing this!
I just saved this one !  all looks ok !
Message 10 of 17
Freedan
I ended up re-installing Maya and the problem seems to be gone. Will never really understand what caused it, heh.
Thanks for the responses!
Message 11 of 17
Zelda_Mary
For the future if it happens to anyone else.
A tip is to check your placement of your UV's once more!
I accedently made my UV's too big without noticing, they were all outside the grid which made the picture blank.
Zoom in at the bottom left corner to check that the little square there isn't the "true" grid.
Message 12 of 17
in reply to: Zelda_Mary
@Zelda_MaryThank you, that worked!  You saved me 🙂
Message 13 of 17
prashantmakwana16
I solved it, just take all your UV's to positive axis of x and y
~let me know
Message 14 of 17
Hi @prashantmakwana16
Glad to hear you solved it. Thanks for sharing it!
Lynn Zhang
Message 15 of 17
HI everyone,
hope you are all well. a small thing, I looked on line and all the solutions so far shows exactly what I have on screen already. Unfortunately when I save my image in UV Editor it still turns out black. Please not I have it in the right x and y, u and v all match and aligned up. I had wished to bring it into another program hence it is important to save the image with the UV's. I never faced this issue before as it had always worked prior before.
I am very much appreciative if you could help me solve this problem. Thank you very much for getting back to me. please find attached a picture of the said issue stated above.
Message 16 of 17
alice.stoll
in reply to: alice.stoll
Hi everyone
I found the Solution on my own. Under Image I didn't have it on RBG and it was on Dim and unfiltered. It works now.
Thank you very much.
Message 17 of 17
asthag195
try changing your render settings and it will help you take out correct UV snapshot
