UV editor Viewport stuck, help please.
BinodAcharya
BinodAcharya
Outpt window :
Choosing OpenCL Device GeForce GTX 1080 Ti. Device Type: GPU Device is available.
00:00:00 754MB WARNING | node "MayaMultiplyDivide" is already installed
00:00:00 754MB WARNING | node "MayaClamp" is already installed
00:00:00 754MB WARNING | node "MayaGammaCorrect" is already installed
00:00:00 754MB WARNING | node "MayaCondition" is already installed
00:00:00 754MB WARNING | node "MayaReverse" is already installed
sean.heasley
Hi @BinodAcharya and welcome to the community!
What do you mean by it being stuck? Can you not move any of the shells?
Have you tried deleting your settings/preferences?
Please let me know if anything changes!
sean.heasley
Hi @BinodAcharya
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
BinodAcharya
I left it for hours and when it didn't respond i had to restart MAYA. Then I tried that again but it didn't respond so I tried splitting the UV's and tried it again.
Then i moved to another project and it is still unmapped.
sean.heasley
Hi @BinodAcharya
So the UV editor is freezing on you?
Can you make sure your GPU driver is the same as our certified hardware list? Our officially supported version for your 1080 is version 398.82. If that is not the version you are on please uninstall your current GPU driver and install version 398.82 which can be found here!
sean.heasley
Hi @BinodAcharya
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
