Unable to open maya 2018
Message 1 of 8
Hi Team,
I am unable to open maya 2018 on my system. While opening system is prompting error which is attached in below file.
Request you to please look into this issue.
Vipin vidhate
Replies (7)
Message 2 of 8
sean.heasley
Hi @Anonymous and welcome to the community!
Unfortunately there isn't anything attached in your post. When you get a chance, can you please comeback and post the image or text of the error here so I can see how I can help you!
Let me know if anything changes!
Message 3 of 8
##- Please type your reply above this line -#
Message 4 of 8
sean.heasley
Hi @Anonymous
I still don't see the error message that is appearing on your machine. When you get a chance can you please post or attach the image here so I can figure out what's happening when you launch Maya?
Message 5 of 8
sean.heasley
Hi @Anonymous
I'm just checking in to see if you're still having this error. When you get a chance can you please post or attach the image here so I can figure out what's happening when you launch Maya?
Message 6 of 8
Hi Sean,
Is may 2018 compatible with Windows 10 home. I have windows 10 home on my
system.
Message 7 of 8
sean.heasley
Hi @Anonymous
While our system requirements say Windows 10 pro, I have home edition as well on my personal computer and it works fine so it should work fine with on your system as well!
Also here's the official system requirements for Maya 2018!
Message 8 of 8
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you're still having trouble opening Maya. When you get a chance, can you please post a screenshot of the error you mentioned seeing in your original post?
If your issue is solved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
