unable to delete shots in camera sequence in maya 2018. work in maya 2014
tonyang1976
Message 1 of 8
tonyang1976
unable to delete shots in camera sequencer in maya 2018. which it works in maya 2014
Replies (7)
Message 2 of 8
sean.heasley
Hi @tonyang1976 and welcome to the community!
What happens when you select the shot in the sequencer and hit delete?
When you get a chance, can you possibly post a video of this issue so I can get a better idea of what's going on?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
Please let me know if anything changes!
Message 3 of 8
sean.heasley
Hi @tonyang1976
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 8
tonyang1976
Message 5 of 8
sean.heasley
Hi @tonyang1976
Is this a scene from 2014 or a new scene you made in 2018?
Even though the side bar doesn't disappear, is it affecting the scene at all?
Message 6 of 8
sean.heasley
Hi @tonyang1976
Message 7 of 8
tonyang1976
new scene from 2018,
no it's not affecting the scene,but it bothers me , also the frame indicator cross over to left side also bothers me...
2018.3 still has this issue
Message 8 of 8
sean.heasley
Hi @tonyang1976
I just did some more testing and this does look like an issue with Maya. I went ahead and logged this with our dev team so they can work on a fix.
Please let me know if there's anything else I can do to assist you!
