Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Time sequencer playing every 11 to 13 frame
1 REPLY 1
Anima_iii
146 Views, 1 Reply
I have one scene that suddenly started to read every 10 frame when playing. What could be the explanation? Is this a bug from the scene itself or a specific parameters I have touched?
I put the scene in the attachements.
Thank you.
Tags (1)
1 REPLY 1
hamsterHamster
in reply to: Anima_iii
Couldn't spot anything specific in your file.
Check the Timeslider-RMB > PlaybackSpeed > .. if it is set to Realtime, then it might skip some frames to approach desired fps. If you want to see the animation i real-time, you might wish to Playblast, otherwise set the PlaybackSpeed to PlayEveryFrameMaxRealTime.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
