Couldn't spot anything specific in your file.
Check the Timeslider-RMB > PlaybackSpeed > .. if it is set to Realtime, then it might skip some frames to approach desired fps. If you want to see the animation i real-time, you might wish to Playblast, otherwise set the PlaybackSpeed to PlayEveryFrameMaxRealTime.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
