Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
the tool is not working
8 REPLIES 8
Message 1 of 9
787 Views, 8 Replies
Hello. I posted this problem before and managed to solve the othe way, but I want to fix this problem. Nothing happens when I click on the icon. The "create render node" does not appear.
8 REPLIES 8
Message 2 of 9
J450NP13
Have you ever used two monitors?
Message 3 of 9
in reply to: J450NP13
Hi!
Yés! I Always used two monitors! I dont know what i did to no longer work.
Message 4 of 9
J450NP13
Hit the home key and while pressing it...hit the left arrow a couple times if it doesn't appear hit the right arrow...basically hit the arrow key opposite the side your other monitor was.
Message 5 of 9
Tanks for help.
I do not know if I got it wrong, but it did not work. however, I believe the prolem is started when I inverted the position of monitors
can you send a image of the keys that you talk about, or give another idea?
tanks again
Message 6 of 9
J450NP13
Look on your keyboard for the arrow keys and press and hold the windows key while hitting the arrow keys.
Message 7 of 9
rflannery
Here's a suggestion I found on this page: http://mayafeedback.autodesk.com/forums/160518-small-annoying-things-to-fix-in-maya-forum/suggestion...
  1. Press Alt+Space.
  2. Press M
  3. Press any one of the arrow keys.
  4. Move your mouse.  The window should snap to your mouse.
Message 8 of 9
Thank you.
His suggestion confirmed the presence of the render node hidden in the left corner off the screen, but I could not move it. I managed to settle with the suggestion of rflannery, but not with the command "move", but "size".
Tanks for help!
Message 9 of 9
in reply to: rflannery
Thank you.
I managed to solve with your suggestion, but not with the command "move", but "size".
Tanks for help!
