the tool is not working
Hello. I posted this problem before and managed to solve the othe way, but I want to fix this problem. Nothing happens when I click on the icon. The "create render node" does not appear.
Replies (8)
J450NP13
Have you ever used two monitors?
Hi!
Yés! I Always used two monitors! I dont know what i did to no longer work.
J450NP13
Hit the home key and while pressing it...hit the left arrow a couple times if it doesn't appear hit the right arrow...basically hit the arrow key opposite the side your other monitor was.
Tanks for help.
I do not know if I got it wrong, but it did not work. however, I believe the prolem is started when I inverted the position of monitors
can you send a image of the keys that you talk about, or give another idea?
tanks again
J450NP13
Look on your keyboard for the arrow keys and press and hold the windows key while hitting the arrow keys.
rflannery
Here's a suggestion I found on this page: http://mayafeedback.autodesk.com/forums/160518-small-annoying-things-to-fix-in-maya-forum/suggestion...
  1. Press Alt+Space.
  2. Press M
  3. Press any one of the arrow keys.
  4. Move your mouse.  The window should snap to your mouse.
Thank you.
His suggestion confirmed the presence of the render node hidden in the left corner off the screen, but I could not move it. I managed to settle with the suggestion of rflannery, but not with the command "move", but "size".
Tanks for help!
Thank you.
I managed to solve with your suggestion, but not with the command "move", but "size".
Tanks for help!
