Hello. I posted this problem before and managed to solve the othe way, but I want to fix this problem. Nothing happens when I click on the icon. The "create render node" does not appear.
Solved by rflannery. Go to Solution.
Solved by J450NP13. Go to Solution.
Tanks for help.
I do not know if I got it wrong, but it did not work. however, I believe the prolem is started when I inverted the position of monitors
can you send a image of the keys that you talk about, or give another idea?
tanks again
Here's a suggestion I found on this page: http://mayafeedback.autodesk.com/forums/160518-small-annoying-things-to-fix-in-maya-forum/suggestion...
Thank you.
His suggestion confirmed the presence of the render node hidden in the left corner off the screen, but I could not move it. I managed to settle with the suggestion of rflannery, but not with the command "move", but "size".
Tanks for help!
Thank you.
I managed to solve with your suggestion, but not with the command "move", but "size".
Tanks for help!
