Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
rotate pivot and scale pivot
In 'Display > Transform Display' there are scale and rotation pivots which you can show. When one changes object's pivot point (D / insert key) one can only change both pivots at the same time. Is there a way to change them (using mouse) separately and not together? If not why?
sean.heasley
Hi @Anonymous and welcome to the community!
If I'm understanding your issue correctly, you want to have the scale pivot at one point and the rotate pivot another?
The reason this can't be changed is because both tools are linked to the same one pivot point. When an object is created, it's assigned a pivot point or gizmo, this gizmo is the sole controller of how an object moves, scales and rotates.
Let me know if this is the information you were looking for, or if I misunderstood your post feel free to let me know and I'll be happy to assist you further!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
brentmc
Yes, pivot editing mode modifies both pivots since that is usually what is desired.
However, pivots are also components that can be selected and transformed independently.
In component mode right-click on the pivot component and select which components you would like to select.
Then select the pivot and translate it with the move tool like any other component.
Brent
Brent McPherson
Principle Software Developer
I've overlooked this submenu - great - thanks
