Reference problem
Reference problem
Reference problem
Hi, i create a caracter and i créate a cycle (swiminig), after i créate reins with ncloth in a first file.
because i have a cycle, i reload them. But upload a few parameter. Do´nt load the mesh.
sean.heasley
Hi @Anonymous
I'm a little confused by your issue.
Are you reloading the scene and not seeing the reins or is it when you reference the scene in a new scene?
When you get a chance, please explain in detail what is happening and we can try and solve this!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
sorry, was a memory problem. Thank.
sean.heasley
Glad you solved it! Thank you for explaining what you did and marking it as a solution Smiley Happy
