Announcements
Maya Project Error: // Warning: The OpenSubdiv Catmull-Clark subdivision method
Hello everyone I'm getting this Error message whenever I open my project
"// Warning: The OpenSubdiv Catmull-Clark subdivision method cannot be applied to non-manifold geometry. outputCloth1 will use "Maya Catmull-Clark" subdivision method for Smooth Mesh Preview."
How do I solve this  ?
Thank you
sean.heasley
Hi @Anonymous
This is appearing because there's a problem with your meshes geometry. If you attach the object here I can take a look at it and let you know whats wrong!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
20-0166c
Community Visitor
Community Visitor
Hi, I have the same problem as well. Hoping there is a way that can solve this, I don't want to repeat this project again from the start.
I highly appreciate immediate help as of the moment.
jdeclanflynn
I am also having this issue with 2023 whenever I press #3 key on a particular project practicing hard surface modeling. Any ideas?
