Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Quicktime playblasts on mac work and then stops
5 REPLIES 5
stevenfila7
670 Views, 5 Replies
Hello all,
So, while animating in Maya 2018, I used quicktime for my playblasts and then all of a sudden the application does not close and I can not restart/shut down or force quit quicktime unless a do a hard reset on my mac.
Has this issue happened to anyone else on a mac desktop?
Please advise and thanks,
Steve
5 REPLIES 5
sean.heasley
in reply to: stevenfila7
Hi @stevenfila7
If you create a fresh scene with just a cube does this issue still happen?
Also, if you playblast with a different format than quicktime does the issue still occur?
stevenfila7
in reply to: sean.heasley
Hi Sean,
Thanks for getting back.  Greatly appreciated.  The only way quicktime works is if I do a hard reset to my machine.  Quicktime works by itself ok but once I start doing playblasts, it seems that the application gets corrupt in conjunction with utilizing maya for playblasts.
I was unsure if maya supports the new quicktime?
Can you please provide step by step instructions how to change my playblasts to another video player because this issue is slowing me down for animation purposes.  The issue does not occur when using VLC player.
I really don't want to save my playblast file, I just want to keep them playblasting if needed be.
Steve
sean.heasley
Hi @stevenfila7
It may be an issue with the new playblast but I'm not 100% certain.
As for changing the playblast settings:
  1. Right click on the timeline
  2. Select the box next to Playblast
  3. Change the format
  4. Then playblast the scene
Let me know how that goes for you!
stevenfila7
Hi Sean,
I actually wanted to change my video player from quicktime to vlc.
Is there an option for that in Maya?
Also, will changing my prefs resolve this possibly?
Please advise and regards,
Steve
sean.heasley
Hi @stevenfila7
You could try resetting your prefs but if the issue is with quicktime there isn't a guarantee that it will solve your issue.
As for your other question, is VLC your default media player? If not make it so and then try to playblast.
