Possible to select only corner edges? (for beveling not inner edges)
BenediZ
BenediZ
often I have to select from dense objects the corner edges, e.g. stairs.
This is a tedious task, as there seems not to be any automatic detection.
But maybe there is a tool or something else?
Attached a screenshot example, after applying bevel already to the corner edges, not the inner edges.
It is even more a problem, as if you just forget a single edge, you can't include it afterwards in your bevel selection.
vfxchris
Select using constraints is what you want.
Select > Use Constraints.
I've made a quick gif showing you how. Notice that the options available to you in the UI are dependent on what you have selected and what mode you are in. I show you how it is different between object and edge mode.
Maya 2022 | Windows 10 | GeForce GeForce RTX 3070
If the post was helpful, please consider hitting the ACCEPT SOLUTION button to help others in similar situations.
BenediZ
Awesome, thanks!
