// Warning: "C:/Program Files/Autodesk/MayaUSD/Maya2024/0.23.1/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsd_layerEditorFileDialogs.mel" line 145.57 : Redeclaration of variable "$layout" shadows previous declaration at line 139. Previous value will be overwritten by explicit initializer.
This error came up when I downloaded my file from another computer. The file includes a Hand Model and Rigging Setup with Joints and Circle Controls. I had just finished Painting the Weights, saved the file, uploaded it to OneDrive, downloaded the file on another computer, and opened the file using the same version (2024).
When I opened the file on the different computer, the hierarchy of the circle controls were non existent and the skin was not binded to the joints.
What happened and how can I fix this??
Solved by hagen.deloss. Go to Solution.
Hi @30096865 ,
That's not good! I hope you found a way through this issue, but if not, here are a few things to note.
Albeit I am no programmer, it looks like the warning has to do with a duplication of a line called Layout, i think that might be associated with your materials, but not your rig. It's also a warning, not an error, but I could be wrong that the issue is unrelated.
Regarding the unbinding issue, things to check for would be:
Hope any of this helps 😄 Warm regards,
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
