Object Noise
Object Noise
Object Noise
Hi All!
I'm trying to figure out if there is a way of adding procedural noise to an existing animation curve. I don't want to create a complex rig with many different nested parentings. I'd just like to animate the object with some adjustable noise on it. 3DSMax's equivalent would be adding a list controller to the transform. Is it possible to do something like that in Maya?
Marcin
sean.heasley
Hi @Anonymous
You could try a plug-in like this.
Or if you want to do it more manually you could just head into the 'Graph Editor', select the curve you want to add noise to, hold down the 'I' key and then middle mouse click a ton until you get the look you're going for.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
