HELP! "File contains unknown nodes or data" can't save
jchen210149
Message 1 of 10
jchen210149
I opened a fbx. file in Maya
I import the textures from Substance Painter
then I assign them to the materials
*I click save and it show "The requested file type does not have write support"
*I click save as, and it show "File contains unknown nodes or data. To preserve this information, the current file type can not be changed."
tried this --->https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-to...
but does not work
need help, thanks alot
Replies (9)
Message 2 of 10
sean.heasley
Hi @jchen210149
Is there history on the model you can delete?
Also, are you saving to your harddrive or a remote location because this sounds like a permissions issue.
Another quick workaround is you can go to Save As and choose Maya.ASCII instead of Maya.Binary for the save format.
Please let me know if anything changes!
Message 3 of 10
jchen210149
Thank you for answering !
I deleted the history and save as Maya.ASCII (Document/Maya/Project/XXX/scene) , but did'nt change
And I tried other fbx. files, when I try to save it(not even working with the textures) problem occur again...
thanks for helping
Message 4 of 10
sean.heasley
Hi @jchen210149
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it? If the file is confidential or under NDA please send it to me in a private message instead of posting it here.
Message 5 of 10
sean.heasley
Hi @jchen210149
Thanks for sending me the file!
I was able to open both the fbx and .MA file and save them without any issues or warnings.
I believe this may be an issue with your permissions or Maya. Are you the admin on your machine? Do you have administrator privileges?
Also, can you try deleting your settings/preferences and then try loading the model in and saving it again?
Message 6 of 10
sean.heasley
Hi @jchen210149
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 10
jchen210149
After resetting the pref
my save button still have the same issue
but "save as" is working now
Thank you very much!
Message 8 of 10
Hi I have the same problem too, the deleting nodes doesn't work for me either..
Message 9 of 10
Hi there,
So I've run into this a few times, you want to save you .ma file as a .mb file. I generally stick to /mb's because they are smaller files sizes among other reasons. Here is the most simple and effective way to work around this problem.
Step 1: Save you latest .ma file
Step 2: close it and open a new seen
Step 3: Save your new empty scene with the same name as your past file just select (save as mb)
Step 4: Import your .ma file into your open .mb file
Step 5: Save your scene , you know have a working .mb file you can save
Hope this helped!
Message 10 of 10
l_korineza
Community Visitor
Community Visitor
"I opened the scene and then I just saved it in another format, 'Maya Binary'. It worked."
