Nurbs Circle Extruded along path render issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have extruded a nurbs circle along a path in a scene to create an extending cable. I began exporting the scene yesterday. When I came back to view the render progress 17 hours later, it had only rendered 27 out of the just over 200 frames, and the extruded nurbs circle was not even visible in the shot. Just to test, I canceled the render and rendered only the current frame, and the extruded geometry of the cable was there, but it was badly deformed and not aligned with the connector on the end of the cable. None of these artifacts are evident in the viewport
So I essentially have 2 questions here:
1) Why is the render taking so long?
2) Why does the extruded surface show up and extrude fine in the viewport, show up distorted in a single frame render, but not at all in final a sequence render?
I am at a loss.
I have attached a sample of the single frame render and the first 27 frames of the sequence render that does not show the extruded nurbs circle geometry. I have also attached the ASCII file as well if anyone would be willing to look at it.
RENDER SETTINGS
Viewport
Distorted/Misaligned Single Frame Render:
Absolutely nothing in final render (Originally EXR beauty sequence converted to .mp4) - Attatched
