Why after installing Maya 2018 not working plugin xgen? The program writes "Unable to execute xgen" error.mel"
Hi @Anonymous and welcome to the community!
Do you have the Xgen plugins enabled?
If so, you might want to try disabling them and then re-enabling them.
You can also try deleting your settings/preferences and then launch Maya and re-enable the Xgen plug-ins.
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
All the best,
Sean Heasley
The problem was solved when I removed the program from the computer and manually deleted the folder "maya", "x gen", "panel" from C:\Users\Users name\Documents. And I re-installed the program-everything worked.
