My cursor is a circle. How do I get it back to normal?
Laurenmdean
Message 1 of 12
Laurenmdean
My cursor is a circle. How do I get it back to normal?  I'm not sure how it got like this.  I'm not able to move rotate or scale with it like this.  I've attached a picture.  Thank you!
Replies (11)
Message 2 of 12
trs_andre
Hi!
Are you using a tablet? If so, it might have something to do with its settings or drivers not being up-to-date.
I remember having similar issues with long clicks in the tablet.
André Moreira
Game Developer / Technical Artist
LinkedIn
Message 3 of 12
Laurenmdean
I'm not using a tablet.  Thank you though!  Any other ideas?
Message 4 of 12
sengkar
Hi Laurenmdean,
I am not sure if your issue is solved. I ran into same issue and I fixed it.
Under "Common Selection Options" in the Tool Settings, I noticed that I accidentally chose "Drag" instead "Marquee".
If you choose "Marquee", that circle will disappear and will change back to arrow as default.
Hopefully this will be helpful if someone run into same issue of Circle Cursor in the Maya Viewport.
Message 5 of 12
diana.yr
Hi there @Laurenmdean
Please let us know if the answer that @sengkar  left was able to help.:) If you can please accept it as a solution it will be super helpful for others with the same trouble. Thanks!
Diana Rouge
Social Media Specialist
Message 6 of 12
Fix
Message 7 of 12
nguyen824
I selected "Marquee" in those settings to get it back to the arrow mouse pointer.
Message 8 of 12
Thank you I tried everything, I never realized I clicked drag, I appreciate your help !!
Message 9 of 12
helalu
I have a kind of similar issue, here are the screenshots. Whenever I try to scale, rotate, or move itIMG_0617.JPG becomes a circle. If anyone has answers, thank you
Message 10 of 12
nguyen824
I don't understand? Try using ShareX or Geforce Experience screen recorder to record your problem.
Message 11 of 12
lrsargent
Community Visitor
Community Visitor
Very helpful, thank you!
Message 12 of 12
may04044
Maybe press "B" key to turn off soft selection.
