My cursor is a circle. How do I get it back to normal? I'm not sure how it got like this. I'm not able to move rotate or scale with it like this. I've attached a picture. Thank you!
Hi Laurenmdean,
I am not sure if your issue is solved. I ran into same issue and I fixed it.
Under "Common Selection Options" in the Tool Settings, I noticed that I accidentally chose "Drag" instead "Marquee".
If you choose "Marquee", that circle will disappear and will change back to arrow as default.
Hopefully this will be helpful if someone run into same issue of Circle Cursor in the Maya Viewport.
Hi there @Laurenmdean
Please let us know if the answer that @sengkar left was able to help.:) If you can please accept it as a solution it will be super helpful for others with the same trouble. Thanks!
I have a kind of similar issue, here are the screenshots. Whenever I try to scale, rotate, or move it becomes a circle. If anyone has answers, thank you
