Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya SVG import BUG
6 REPLIES 6
6407 Views, 6 Replies
Maya SVG import BUG
maya 2017 all versions
import svg or paste from Illustrator have a BUG with simple object
6 REPLIES 6
file
mspeer
Hi!
The outside curve direction is reversed here, which leads to wrong normals.
I can't say if this is a problem in Maya or the imported SVG-file .
You can try to correct this outside of Maya, or inside Maya use "Create Curves from SVG" and then extrude manual using Bevel Tools.
sean.heasley
in reply to: mspeer
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
john.paul.giancarlo
hello the direction of the curve needed to be reversed!
here the maya file fixed for you !  I also included the fixed svg file in the attachment
the problem was in the svg file !   🙂 . not a Maya problem!
in reply to: john.paul.giancarlo
othe 3d software work nice without fixing svg or illustrator file. only maya have this bug. this is a bug becouse only 1 letter with wrong direction.
 file  - Softimage only import file without any manipulations with svg
I have a lot of svg files with bugs in maya and perfect worked in Softimage.
