Maya out of device memory, but only using 20-30% of memory
Message 1 of 17
Hi, I'm having issues with Maya 2018 whenever I trust to use edge loops and smooth. The object glitches into strange shapes, or disappears completely, which usually can't be undone.
Maya gives this error:
OpenCL Error: Out of device memory.
OpenCL Error: Out of resources.
I have 16GB RAM, but when I look at task manager, maya is only using 20-30% of memory, even with priority set to high.
Any ideas how to make maya use more memory? It obviously needs it, I'm totally stuck with deadlines fast approaching.
Replies (16)
Message 2 of 17
Message 3 of 17
mspeer
Hi!
OpenCL uses GPU and GPU RAM.
What subdivision type do you use, how much subdivisions, polygons?
For further help please upload the scene-file.
Message 5 of 17
sean.heasley
Hi @Anonymous and welcome to the community!
@mspeer made a good point and if you're using too many subdivisons, making the object too high poly, that could cause the memory issue.
If you aren't doing that or the issue is still occurring, please zip and attach the scene file here or via dropbox/google drive or another file sharing program so we can take a look at it.
Let us know if anything changes!
Message 6 of 17
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the information I provided yesterday help you at all?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 17
Apologies! It is a very low poly object so that isn't the issue, it looks like it's most likely down to my graphics card (which is built in due to it being a laptop) I am still having the issue, but this is most likely just down to my laptop. The move, scale, and Rotate functions are also currently not working now, which I think may be a 2018 issue so I have switched back to 2017
Message 8 of 17
sean.heasley
Hi @Anonymous
When you get a chance, can you please post your laptops hardware specs so I can see if there are any issues that might be causing this memory error?
Steps to find your pc specs can be found here!
Let me know if anything changes!
Message 9 of 17
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. When you get a chance please post your hardware specs here so I can take a look at them!
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 10 of 17
Message 11 of 17
sean.heasley
Hi @Anonymous
What are you using for a GPU?
Also, does this happen in an empty scene with Maya or a specific scene?
Message 12 of 17
sean.heasley
Hi @Anonymous
I just wanted to check in to see if you were still having this issue. When you get a chance, can you let me know what GPU you are using?
If your issue is solved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 13 of 17
I am having the exact same problem, I don't know how to know which GPU I am using, in case you ask that to me, this are my laptop specifications:
Message 14 of 17
sean.heasley
If you open the start menu and type Device Manager then navigate to Display Adapters you can see what your GPU is. You can then Right Click the GPU and select 'Properties' and select the Driver tab to see the driver version.
When you get a chance, please let me know what GPU you have and what version!
Message 15 of 17
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
Message 16 of 17
Hi, thank you, then my GPU is Intel(R) HD graphics 620,
version 21.20.16.4534, now could you tell me please how to solve the
problem with Maya and the Smooth Mesh preview after adding a loop cut?
Message 17 of 17
Hi, thank you, my GPU is Intel(R) HD 620 version 21.20.16.4534, now could you tell me please how to solve the problem with the Smooth Mesh preview in Maya 2018?
