Posting for a friend:
" Hello MASH folks, I am suddenly having issues with Maya scenes containing complex MASH networks. I have been saving the Maya scenes in ASCII format with no problems. Then, starting today, my scenes began loading without my MASH nodes. No bueno. I am thinking the MASH plugin is corrupted because of this error: # Error: TypeError: file C:\Program Files\Autodesk\Maya2018\plug-ins\MASH\scripts\mash_repro_utils.py line 687: 'NoneType' object is not iterable # Anyone experience this? Any magic solutions? Can I just download the MASH plugin? or I am forced to do a full re-install? Jennifer "
Solved by sean.heasley. Go to Solution.
Hey @Anonymous
A quick fix that may work for them is to simply unload the MASH plug-in and reload it in the plug-in manager.
If that doesn't work then they would want to try deleting their settings/preferences which would reset all of the MASH scripts back to default.
Please let me know if either of these work for them or if they need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if your friend needs any more help with this. Did the suggestion I provided yesterday work for them?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
I'm having the same issue-
I've tried the plugin check/uncheck, wipe preferences, and updated to the latest Maya (2018.4)
The only 'unique' thing about the scene I'm running, is that it houses 3 separate instances of Mash. Could that be causing a conflict? If I delete all but one, I still maintain the issue.
Please advise, and thanks for your time.
