Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Copy or Preserve Blend Shapes when deleting History
2 REPLIES 2
1607 Views, 2 Replies
Hey guys, I'm working with Blend shapes in Maya, I have a mesh that was supplied to me by an artist that contains rigging and blend shape data. I have another mesh that I need to merge and weld into the original model, however when working on the mesh it is extremely slow performance wise due to the history.
When I try to delete the history for the mesh it also removes the blend shapes on the model. I have been searching for a way to fix this, like deleting non-deformer history, but this doesn't really do much.
I also read that I could make my modifications to the mesh then copy the blendshapes from the previous mesh to the newly modified one. However I haven't actually been able to find out "HOW" you do this.
I could really use some advice as I've been stuck on this issue for a couple of days.
Thanks!
2 REPLIES 2
sean.heasley
Hi @Anonymous and welcome to the community!
This tutorial might help for transferring the blend shapes:
Also this thread might have some useful info for you on deleting history without deleting the blendshapes!
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Technology Administrators
