Hi. My maya 2017 keeps crashing randomly and I don't know why.
The screen freezes and turns white, and I have to manually close the process from the task manager.
I have recently upgraded my ram from 8gb to 16gb thinking that maybe this was the problem, but it turns out It wasn't.
I am using Windows 10, i7 4710 CPU, gtx950m Gpu and a 120gb SSD, in which both maya and the project I'm working on are installed.
I know the system is quite old but I don't think this is enough to make this crash so frequently. As soon as I throw in a somewhat detailed head model for example, it starts getting slow, the input delay gets around 2-3 seconds and then it crashes.
How can I solve?
Have you tried disabling nvidia before using maya? That solved my problem, although it sucks... Go to start and type "Device Manager". Under "Display Adapter", you will see your nvidia version and right-click, disable it.
Hi again! Apparently using my default intel gpu and not the dedicated gpu solved the issue, but the it gets so slow it is almost impossible to use, especially on models that have a high number of polygons. Is there a way to make the nvidia card "work" properly with maya again? It doesn't seem to have any issues with other programs...
Hi, how about, enable the nvidia and disabling intel HD graphics? Somehow having 2 graphic cards makes maya crash often. I don't know why, but my laptop had that problem, yet my PC didn't (my PC only has Nvidia and no integrated graphic card), so maybe it works?
