Maya bevel problem (going wrong ! )
mikhailkonstantin3d
Message 1 of 14
mikhailkonstantin3d
hello everyone .. I am in a job of making coffee machine .. but am having a problem with the bevel and here is the photos this is it .. i beveled some of it the front sidethis is it .. i beveled some of it the front sidethe red one is good .. thats how it should be like you know .. but the blue it's going wrong !the red one is good .. thats how it should be like you know .. but the blue it's going wrong !a close one to the left side of the machinea close one to the left side of the machinethis is the right side it's very bad !this is the right side it's very bad !the right sidethe right sidefrom here you see the right side is very bad !!from here you see the right side is very bad !!
I attached the Maya scene file if you wanna take a look .. and I you know or figured out what is the problem and how to fix it .. please tell me .. thanks a lot
Replies (13)
Message 2 of 14
The bevel tool is always being improved. Maybe in a couple of versions from now you can check it again.
Message 3 of 14
mikhailkonstantin3d
I have maya 2017 and can't download the 2018 !! I uninstalled it because of some problems and can't reinstall
Message 4 of 14
Not sure but, is this what your expecting/looking for?
Message 5 of 14
mikhailkonstantin3d
gosh .. yaaa !! is the other side is the same ? can you please tell me how you fixed it ?
Message 6 of 14
mikhailkonstantin3d
I tried your way .. the other side can't made the same .. the problem is still exist !
Message 7 of 14
Yes both sides are the same.  I didn't fix anything, just made sure that every edge was picked and kept all the original settings, then hit bevel and adjusted the setting shown. I actually did all edges at the same time (both sides).  Maybe that's it? You could try deleting history on the object, that might be causing an issue.  Hope that helps.
Message 8 of 14
mikhailkonstantin3d
thanks .. can I ask you to send me the file ? it's just can't be done with me !
Message 9 of 14
Sure! I would maybe try, if you haven't already, Go to {edit > delete by type > history} then also go to (edit > delete all by type > history) Then also in the bevel tool settings try going up to (edit > reset settings) and then attempt it again.  Also be very careful when selecting the edges. I have had weird things happen when grabbing a stray edge and then trying to bevel. File is attached
Message 10 of 14
Sorry it wouldn't let me edit my last reply.   It occurred to me that you may not be able to open the .mb file I attached in the prior response because I'm using Maya 2018.4 and I think you said you were still using 2017 so here is it as an .obj
p.s. I could be wrong but, I don't think its the version of Maya that makes the difference on where it worked for me and wasn't for you.  I would try doing the things I mentioned in the prior post, if you havent. I think that might fix your issue.  Anyway hope it helps.
Message 11 of 14
Lol sorry just realized I didn't attach the .obj so here it is.
Message 12 of 14
mikhailkonstantin3d
thanks you a lot .. the obj you sent is working very well .. but the way you told me to do isn't working ! i'll try to reinstall maya 2018, its just can't be installed and Autodesk support isn't replaying to my message
Message 13 of 14
mikhailkonstantin3d
hey .. I reinstalled windows 10 that I have !! so I could reinstall maya 2018 after I uninstalled it.. and the whole problem was about maya 2017 is the wrong I made it with maya 2018 and it worked very good
Message 14 of 14
mikhailkonstantin3d
well .. maya is very nice software as for me .. and it has very nice things
