Maya 2019 LT- Unable to send scene to Unity 2019.
dalekilgorejr
Observer Observer
dalekilgorejr
Observer
Observer
In sum while attempting to send a scene to Unity 2019 I get the following Error Message: A valid Unity Engine must be locally installed.
Note that I am using a MacBook Pro with macOS Mojave.
Any help world be greatly appreciated.
sean.heasley
Hi @dalekilgorejr  and welcome to the community!
Are you trying to use the Send to Unity function?
If that isn't working, can you try exporting an FBX and see if that imports into Unity ok?
dalekilgorejr
Observer
Observer
Thanks for the response. Yes I am attempting to use the send to Unity
Function.
Also, I have exported a very simple Maya scene using the FBX extension.
It easily imports into Unity.
sean.heasley
Hi @dalekilgorejr
It seems there was a similar issue in this thread.
I'd recommend reading through that but the solution was:
I might have found the issue. It looks like a slash vs. backslash issue.
Try this:
optionVar -remove "UnityPath";
optionVar -sv "UnityPath" "C:\\Program Files\\Unity 5.0.0b21\\Editor\\Unity.exe";
Let me know how it works.
You could try using these lines in your script editor but you may need to change the file path to match your Mac set up.
dalekilgorejr
Observer
Observer
How do I find the file path using Finder on a Mac?
sean.heasley
Hi @dalekilgorejr
It should be wherever you installed Unity.
sean.heasley
Hi @dalekilgorejr
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
