Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2019-2020 crash on launch, Mac Catalina
4 REPLIES 4
1000 Views, 4 Replies
Hey Autodesk community!
Having an issue where Maya 2019 and 2020 crashes upon launch.  Specifically on 2020, I'm getting a bit more information from the system about what's going on... First time posting for help, so give a shout if I'm missing any deets!
Here are some specs:
MacOS Catalina 10.15.3
MBP Retina 15" Late 2013
2.3 GHz QuadCore Intel i7
16GB RAM, 1600 MHz DDR3
NVIDIA GT 750M 2GB, Intel Iris Pro 1536 MB
Attempted reinstalls multiple times, and with different versions of Maya.
Added Maya to Accessibility and Full Disk Access Security & Privacy settings.
Attempted launching from Terminal.
Also attempted launching from Applications folder and right-click > "Open."
All same results 😕
The most stable results I've gotten: Consistently works properly upon 1st launch of fresh install.  Closing and launching 2nd time always fails (as below). Consistently alternates between launch success and failure.
Each time Maya launches, gets to license page BUT displaying error message:
Fatal Error.  Attempting to save in /var/folders/vp/_9ddn71n4758t8q027qrmq5r0000gn/T/Kathy/20200414.1616.ma
And Terminal displays this when launching from there:
Kathys-MBP:~ Kathy$ /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/Maya
Stack trace:
  4   libsystem_pthread.dylib             0x00007fff6bd1a25b pthread_mutex_lock + 0
  5   WacomMultiTouch                     0x0000000115ef2e46 CMacMultiTouchAPI::~CMacMultiTouchAPI() + 48
  6   WacomMultiTouch                     0x0000000115f116e1 WacomMTInitialize + 136
  7   libWrapperWacom.dylib               0x0000000115ed5c5a Gestura::QWacomMTDeviceImpl::initialize() + 42
  8   libWrapperWacom.dylib               0x0000000115ed5bf9 Gestura::QWacomMTDevice::initialize() + 41
  9   libGestura.dylib                    0x000000010fda50bf Gestura::TouchEventServer::initializeWacomWrapper() + 79
  10  libGestura.dylib                    0x000000010fda4712 Gestura::TouchEventServer::TouchEventServer(Gestura::GestureServer*, char const*) + 514
  11  libGestura.dylib                    0x000000010fdbf08f Gestura::GestureServer::GestureServer(char const*) + 191
  12  libExtensionLayer.dylib             0x000000010f8931ff QmayaApplication::InitializeGestura(AutoCam::CameraOperations*, AutoCam::Renderer*, AutoCam::ViewCube*) + 255
  13  libUIComponents.dylib               0x000000012c0efe2e libUIComponents.dylib + 81454
  14  libUIComponents.dylib               0x000000012c0f0c4b libUIComponents.dylib + 85067
  15  libCommandEngine.dylib              0x000000010fe59176 TmetaCommand::name() const + 1654
  16  libCommandEngine.dylib              0x000000010fe8685d myInput + 49389
  17  libCommandEngine.dylib              0x000000010feb5cb6 setMelGlobalStackLevelPtr(unsigned int (*)()) + 5206
  18  libCommandEngine.dylib              0x000000010fe8685d myInput + 49389
  19  libCommandEngine.dylib              0x000000010fe86680 myInput + 48912
  20  libCommandEngine.dylib              0x000000010feb3376 SophiaExecutable::evaluate(void*) + 70
  21  libCommandEngine.dylib              0x000000010fe61678 TcommandEngine::executeCommand(Tstring const&, bool, bool, TmelCmdResult*, unsigned int) + 936
  22  libShared.dylib                     0x000000010d214a2d TsceneOperator::newScene(bool) + 653
  23  libShared.dylib                     0x000000010d20e549 TfileCmd::handleFileNewFlag(TargDatabase&) + 105
  24  libShared.dylib                     0x000000010d20ce5f TfileCmd::handleFlags(TargDatabase&, TsceneFile*, TnamespaceSwapper*, TgraphDiff*) + 1263
  25  libShared.dylib                     0x000000010d205658 TfileCmd::handleFlags(TargDatabase&, Tstring const&) + 4104
  26  libShared.dylib                     0x000000010d20382e TfileCmd::doCommand(TargList&) + 622
  27  libCommandEngine.dylib              0x000000010fe59176 TmetaCommand::name() const + 1654
  28  libCommandEngine.dylib              0x000000010fe8685d myInput + 49389
  29  libCommandEngine.dylib              0x000000010fe86680 myInput + 48912
  30  libCommandEngine.dylib              0x000000010feb3376 SophiaExecutable::evaluate(void*) + 70
  31  libCommandEngine.dylib              0x000000010fe63820 TcommandEngine::sourceFile(Tstring const&) + 208
  32  Maya                                0x000000010993c35a Maya + 99162
  33  libExtensionLayer.dylib             0x000000010f8821a2 Tapplication::start() + 82
  34  Maya                                0x0000000109937d05 Maya + 81157
  35  Maya                                0x000000010993763b Maya + 79419
  36  libdyld.dylib                       0x00007fff6bb1a7fd start + 1
1
4 REPLIES 4
patrick.schock
Hello @Anonymous,
thanks for posting this issue. As a first step, can you please try the suggestion from this post: Maya - Fatal error (Attempting to save...)
Editing the Maya Env file and adding this line might solve the issues:
MAYA_DISABLE_OPENCL=1
Here are instructions where you can find the Maya Env file on your MAC: Setting environment variables using Maya.env
Looking forward to you reply, if you had success!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
in reply to: patrick.schock
Hello @patrick.schock!
I have the exact same problem as the topic starter.
I opened the Maya.env file with TextEdit and pasted the code line that you mentioned. After saving the file and opening Maya again, the same Fatal Error popped up.
What can I do to fix this? Hope to hear from you!
patrick.schock
Hello @Anonymous,
can you please try to reset the user preferences by following the instructions from this article: How to reset the Maya Preferences to Default.
Please make sure that Maya is closed, then start to rename the related folder.
Looking forward to your reply, if this helped.
Best regards,
Patrick
warnold1
The crash is pointing to the multi touch feature. It’s possible the Wacom driver is not compatible, or there are multiple devices with multi touch capabilities, ie tablet, track pad, Magic Mouse generating a conflict
there is a preference option to enable/disable the feature.  If Maya starts up once, can try to turn off the option
can try disconnecting the tablet to see if Maya launches
Wayne Arnold
Developer
